Iso Clamp removal... Am I missing something?
Hilljack68
6:46 AM
Ohio
I'm swapping out the 8.25 rear end in my 73 Charger in favor of an 8.75, and I'd like to delete the iso-clamps. I already picked up a '72 rear end. Instead of dealing with the mis-matched hole sizes on the perches/springs, couldn't I just source springs and shock mounts from a 71/72 Charger and be done with it?
I've read articles and posts until my eyes went all Marty Feldman, and no one has mentioned this as a possibility. Is there something I'm not taking into account?
(And no, I don't want to go Poly for the Iso-clamps; I just want them gone.)
Thanks guys
Yes. It's what I did with my RR. Except I had bushings made cause mine was a 73-4 8 3/4 rear so it needed them for the leaf spring/perch for the other leaf spring locator pin.
So a 71/72 rear end with 71/72 springs should require no mods?
I don't believe so just check you shock length I know I have switched those out but it's been awhile I forget what I ended up using.... Also I think they have a different front hanger as far as the bolt size in the front bushing..
Yeah, I'll have to do a little digging. Thanks for the input.
I used mopar super stock springs when I changed mine over. I did have to put in shims to change the pinion angle. (Not to get this thread banned but I’d like to get rid of the springs.)
Oh crap, I didn't think about that... the pinion angle. Dumb question, but where did you have to shim it?... on the spring perch?
Yes between the spring and the perch. Mine was off a mile, 7 degrees IIRC.
I made my own shims, so the pins worked out. I had a broken shock mount so I also made bottom plates.
My car is a Frankenstein lol.
Undercar pics are from a few years ago. When I raced this setup I put old school shock extensions on.
The shocks are a plain monroe or something, probably the C-body shock mentioned in the DC manuals.
The shims I made on a CNC so I just milled the big circle on one side and drilled the hole on the other.
Usually when I make stuff I over build it.
I can't remember the year of the housing, it may have been a 71-72, so the center hole may have been different and why I had to make something special. I did all this in the late 80s.
This is a little cleaner. Works better on the strip.
Man, those are serious shims! Thanks for sharing - much appreciated
Told you I tended to over do it, especially back in those days
73/74 spring retaining studs are 3/8” with a hat shaped bushing to accomodate the isolation pad while 71/72 are 5/16” studs.
The 73/74 bushing on studs makes a step on the springs. I would remove those and replace the stud with a shorter piece. The bushing step could interfere with a correct seat of the axle pedestal over the springs.
