Steven73SE
Ok guys working on my 73 charger project, finishing up getting the body patched on it, and getting ready to put the rear end and k member back in it. The car was originally a 318 automatic, but i found a 440 and 727 big block transmission for sale in my area, and was looking at doing a swap. I've done a bit of research on it and found that the motor mounts are different, so whats a better option, getting a new K member or the conversion mounts? Also if anyone can give some extra info and clarify what else must be done to do the swap? I have a rallye dash out of an SE and a hurst shifter, what will it take to make these work with the big block? Also, I was looking into tubular k members for some weight savings and added room for headers, and couldnt find one for a 73 B body. I found them for earlier models and for E bodies. Any suggestion on this? Good idea or bad? Is there one available for the big block? Will they support one, and can they handle a mild street built 440? I also have an 8 3/4 rear for the car, not sure what the gear ratio is.
