fine69
I’m in unfamiliar territory, fellers. I noticed earlier this spring that the inside of my RR tire has fluid on it. I did my research on fbbo and figured the axle seal is leaking. So I read it could be from pressure and the vent might be clogged so I removed it, cleaned it up, and was able to blow through it and cranked’r back in.
I guess my question is, will it stop leaking if the issue was the clogged vent and it is no longer clogged or is it too late and the seal has to be replaced regardless?
