Longer wheel stud help
gtxno1
5:19 PM
Freehold N.J.
Hello everyone need a little help I just purchased aluminum wheels for my 67 unfortunately I need longer wheel studs at least 1/2 longer than stock my fronts are the original 4 piston disk brake set up and the rears are 8 3/4 what is everyone using thanks
Check out the thread "Torque thrust wheels vs standard lug studs" (tires and wheels forum) or just search "longer lug studs".
For some reason Ford Crown Victoria studs sound familiar. Get on the Dorman site and compare diameters.
These are the long back ones.. you could cut them down..
Fronts might be tricky with the disc brakes
The front ones are the issue I have the original 2 piece rotor up front
I am using Weld Pro Star wheels and have ARP wheel studs front and rear. My lugs are open end.
