- 6:59 AM
- May 27, 2015
- Gaston South Carolina
What are you guys doing to keep the new master cylinder’s from rusting ? Mine looks like crap after only 6 months. Thanks Mike
Thank you. That would be helpful. I’m not trying to be factory correct, just don’t like the rusty look.it depends if you want it to pass as factory original or not. factory original is bare metal. and for good reason. most paints do not hold up well against brake fluid seepage from joints and the upper seal.
i've restored a few with an iron phosphate coating that holds up well to west coast sea air. But even after 4-5 years out in the car port, some rust is evident. iron phosphate is blackish and looks much like aged cast iron with patina.
a zinc phosphate coating (in black) would be my next choice for durability and fighting rust, while still having the appearance of bare metal with patina.
there are some paints that may look like metal, but I've not used them on a master cylinder. a rattle can paint damaged by brake fluid make look worse than the bare metal rusty color you have now.
i've considered using a ceramic paint, also in a bare metal color, that bakes on and should stand up considerably better against brake fluid damage.
I took some pictures of my assorted restorations years ago, and was able to take more pictures after a few years of street driving. If I can find them, I will post some.
Dam Mike I thought you took care of your cars.What are you guys doing to keep the new master cylinder’s from rusting ? Mine looks like crap after only 6 months. Thanks MikeView attachment 1554239
How does it hold up to brake fluid drips?I paint them with “cast blast” which is a close approximation of raw cast iron…
Almost all DOT 3 these days is synthetic, still lifts paint quite well.Clear or cast blast (Seymour)
And I always use synthetic fluid regular DOT3 is nasty stuff.
That sheeeet gets on everything. LolPOR 15??
And stays put!That sheeeet gets on everything. Lol
