There were (VERY rare, and not very good) Nascar single four manifolds for max heads. Just like the two fours crossram, the had a cast-in valley cover that sealed the valley and China wall. Think 337 manifold, only not near as good.
I have used a single 4bbl TM7 welded up to maxwedge port size. Sealing the valley was a nightmare, with the iron heads. Would have been much easier with aluminum head that don't have the cutouts between ports.
After several failures of homemade valley pans, the final best solution turned out to be..... the stock bathtub seal, cut to ribbons, top of the port removed, and dual home-cut from gasket material side gaskets, set of four, one on each side of the cut up valley pan.
I have a couple pairs of Superformance maxwedge gaskets that I'm gonna use next time. I think I have a couple different thicknesses.
