Charg68
Hey, anybody out there with a stripped down 68 B body? Finally getting back at my charger. Life got in the way for the last 5 years. Can't believe it has been that long. Gotta get this thing done before I get my first pension cheque!. I need a measurement from the top of a b body rail at the front end. Close to the front end on the top is a 1/4 inch hole. If you put a solid bar across the rear package shelf and over the window opening sticking out over the rail, I need to know the distance from the top of the rail at that 1/4 inch hole to the bottom of the pipe. Have attached pictures to hopefully illustrate what I am needing. By the way, my cowl is off the car so the pipe I am using is sitting in a little depression in the lower windshield frame.
