Member who posted on process of restoring/cleaning the yellowing off Overflow bottle?
Fran Blacker
1 of 27
11:49 AM
Connecticut
Wish I thought of peroxide when I was working. We had industrial strength peroxide 80% pure. Put a rag in it a throw rag on the concrete floor it the rag would burn. If you left a strip of .0078 bronze laying the tank we ran it through it would put holes in the metal. You had to dump the tank.
chtampa
11:49 AM
Tampa, FL
There are a lot of readily available acids to experiment with. I keep them all in my shop and different uses pop up from time to time. Concrete Cleaner, RustOff, TarnX, Lime Cleaner and I know I have forgotten some. TarnX works wonders on electrical terminals.
mrmolding
10:49 AM
CA
I got a very stained 73 overflow reservoir and was happy to find it since they are not reproduced. I saw that original video, so I tried the H3NSO3 twice and it did nothing. I let it soak in a 5 gallon bucket for a week in the summer sun. But I will admit I did not know what activator to use. Then I soaked again with a little bleach submersed in water and that helped a little. I've seen other videos with peroxide and rice but got distracted by other things. So, I put it back on the shelf for another day. Perhaps I'll try the retro-brite.
QuickBpBp
11:49 AM
SE PA
I am in the process of doing it now and I used distilled warm water and it has been soaking for about 3 hours.. I will let others know my results $13 for the acid and the water so not a lot invested..
Sixpactogo
10:49 AM
Eau Claire, WI
I seem to remember watching a video on the subject a while back where the guy tried vinegar and baking soda, then some sort of acid and other liquid. After a couple weeks of messing around with it he tossed it in the recycle bin and bought a new one. I bought a new one first. Lucky for me someone tooled up and started remaking the one I needed.
mrmolding
10:49 AM
CA
I think the word remaking triggered me. :) I thought I'd done a fair amount of due diligence before I got my 73 RR that was missing everything! With my 70, you just hop on eBay or a bunch of awesome vendors, not to mention other members here, and get mostly whatever you need. Overflow bottles, quarter panels, wheel opening trim, no big deal. If 73-74s start getting more parts reproduced, I wonder if they'll skyrocket as well in value. Glad I found my overflow bottle when I did, and QuickBpBP has helped me fill in the part gaps as well. Here's to hoping that someone starts making parts for the 73-74s as well. Who knew I'd spend three weekends polishing a bottle that I would have passed on in a junkyard 40 years ago! :) Complaint done and looking forward to the results. :)
chtampa
11:49 AM
Tampa, FL
Just used the concrete cleaner on the aluminum floors of my Silver Sides bus cargo areas. It took all the rust off from the wet steel parts that had been stored there over the last 35 years.
QuickBpBp
11:49 AM
SE PA
Ok so here is the result 24hrs later.. IMO not worth the time or money. The $1 spent on rice to shake clean the inside with soap and rice did more than the 24 hr soak.. I only see that it lightened it and blended the discoloration NOTHING like the video. Before and after pics..
dadsbee
11:49 AM
Midland Ontario, Canada
Guy that did the video is still giggling about where he edited out the swap for a new bottle...
Ceedawg
11:49 AM
Va
I would think the first thing is to figure out what the yellowing is? Is it scum or discoloration? then find a concoction that counteracts that.
mrmolding
10:49 AM
CA
QuickBpBp results are the same as mine after using the H3NSO3 as in the video. I then put it in a 5 gallon bucket with water and a little bleach made mine a little less dingy after a few days. Looking forward to seeing what someone else tries. :) I guess the good thing is that if I do more of a restoration and put the carbon canister in front of the bottle, it's not that noticeable anyway.
SureGrip
11:49 AM
Central Maryland
The key to the process is the UV light (Sun or lamp). Many videos talk about this.
QuickBpBp
11:49 AM
SE PA
It was in sunlight for at least 12 hours I put it outside then my garage at night just so animals would not knock it over or drink it….
