67 Coronet Conv
Yep same thing happened to me years ago, more like a pinging sound in the exhaust. Backed off the timing and all is good.Detonation...
No. After driving more It appears that the noise only occurs when I push hard on the gas pedal and down past 3/4 and to the floor. It even did it in 3rd gear at around 45 to 50. When I gradually push the gas pedal down even at 70 mph it didn't make the noise.Beep69....Did you find your issue?
I would check the axle bearings. When they go they make a knocking sound that comes and goes with speed. Usually sounds like its coming from under passenger compartment.No. After driving more It appears that the noise only occurs when I push hard on the gas pedal and down past 3/4 and to the floor. It even did it in 3rd gear at around 45 to 50. When I gradually push the gas pedal down even at 70 mph it didn't make the noise.
