I try to use as much steel as possible only using rubber for a short connector usually an inch or 2.
Agree, I might skimp on some things when building a car but not on something that can blow up and kill me.I try to use as much steel as possible only using rubber for a short connector usually an inch or 2.
It's like being on an EOD team, you only get one mistake.Agree, I might skimp on some things when building a car but not on something that can blow up and kill me.
Can you just use a rubber gas line to the carb?
Thanks!
Awesome idea.Not to get nosy, but why? I would assume the engine moving and rubber degradation might cause problems long term. I know repops are available for a lot of cars, or make your own. If you do't have a pattern, use #9 copper wire or coat hanger to make one and brake line from the parts store.
Is the stock metal gas line to goes from the fuel pump to the carb important? Can you just use a rubber gas line to the carb?
Thanks!
One car fire is one too many. At least you were not turned into a crispy critter.It isn't TOO big of a chance having a problem. I have been driving since I got my permit in 1974. In all that time, I have only had ONE car burn and be totaled by the fuel line popping and spraying on the hot engine. Just one car destroyed in all that time! So why worry?? (Car was a Mercury, so no Mopar was harmed......)
I wrap it as tight as possible with tape, masking or duct, then cut thru the middle of the tape with a cut-off wheel in a die grinder. Sometimes even leave the tape on to insert the line into the fitting.How do you cut that stuff? I've tried before and it gets all frayed and a complete mess. No to mention stabbing yourself with 1500 barbs.
