You'll probaly have to settle for an old used one... Do you need the male or female side? Another option is to swap both sides of the connector to the common two wire T connector..
Yeah, if you swap it but save the the half you have, down the road you might find the other side & you could swap in the correct connects if your the "Detail Nazi" type... If not then the T style connector is a completely acceptable permanent fix
I’m pretty sure have seen that angled plug available somewhere, but it was long time ago.
As mentioned it was used on 3rd gens on the seatbelt warning system (seat sensors and 72/73 seatbelt main harness) but also on the lights on buzzer pigtail/harness provision.
Most Napa shops will have that Packard 56/58. May look a bit different with the lock tabs. Evans would be another potential place to get an OE looking one.
I can look in my stuff for a 2 way. Let me know what you need. Both halves and all connectors? I use them on this AC compressor relay set up.
