- 1:16 PM
- Jan 16, 2011
- NorCal Sierras
Disclaimer;
I'm just spit-balling here, trying to help or ask pertinent questions
so others/knowledgable can chime in & help too,
Please don't take offence to my comments or questions...
What ignition & timing ?
Was that old cam installed advanced, straight up or retarded ?
{more initial ignition timing or an advanced camshaft can help down low (some), but
will generally hurt on the big end, but a retarded ignition timing or camshaft for your specific engine combo,
will wake up more on the big end/thru the traps, especially on a 1/8 mile pass}
What RPM are you leaving the line at ? {on the trans-brake I assume @ 4200 rpm}
What rear shocks ?
What type of rear suspension ?
What size rear tires ?
How much front end travel ?
{your fenders vs the tires/suspension unloaded/travel, I see you said it lifts the tires 8"s}
Slicks {are they Bias or Radial} or running Drag Radials ?
What are you going thru the traps MPH/speed & RPM ?
sorry if it's a bit redundant...
Generally speaking;
Early tire spin or unloading the chassis after launch/spinning the tires
in the 1st 330ft, will "generally" show as higher MPH usually vs the ET #'s
the shocks, suspension or settings could have a bunch to do with it too...
Improve 60 ft times the ET will pick up a bit...
{Obviously, but significantly the 1st 330ft is the most important for real ET changes,
ET is the chassis/engine combo #'s working, basically MPH is HP}
When the car leaves ?,
does the front end stay up & on the rear tires when pulling the front end
going out to near 60 ft {or past}, than settle down easily ?
{Do you have any video you can show us ?}
or does it drop down fast & unload the rear tires ?
Possibly ?
getting tire spin, hense a bad 60ft for that combo,
than using up/wasted all the bottom end torque,
basically making you run out of gear/engine capabilities on the top end ?
MAYBE ?
{5.13:1 is a ton of gear for a wedge engine, if only spinning 6500 RPM, leaving @ 4200 if you don't have a
30"+ 12"+ wide tire, even in the 1/8th mile if your tune/chassis/shocks etc. isn't right}
Where does your camshaft card say it should make the most Peak Torque
& at what RPM range ?
It maybe just falling on it's face on the big end too,
but the 60 ft should be better !!
Anyway Good Luck, with your new build, happy Moparing
What rear shocks ?
Generally speaking;
Possibly ?
MAYBE ?
