- 12:34 AM
- Jan 19, 2018
- calvert city, ky
Metaldad, what kind of spark plug wire looms are you using?
Do these Valve Covers look familiar?Depending on your distributor you may need to clearance the pass side valve cover just a smidge.
I "test fitted" the HP manifolds and the fit but the right side manifold is just a gnats *** away from the valve cover. Likely to get hot.I hope you're using headers. I couldn't install mine with hp manifolds.
I use the ARP bolts for cast aluminum valve covers.I put this set on my 440 yesterday.
First of all, I had a heck of a time getting the two bottom bolts on each cover in. They wanted to get too close to the cover and couldn't get a socket or wrench on them. Has anybody else had trouble.
Also, there's no place for a breather, how's the motor supposed to vent, do I need to remove one of them and drill a hole?
If I'm understanding you correctly, it sounds like you have the crankcase ventilated, but not "positive" ventilation, unless by "vent valve" you mean a PCV valve.On the picture i have to screw in type breathers, but after i changed the setup for better crankcase vent.
I installed a filler cap on the driver side (front) and knocked out the blank on the rear side and installed a vent valve there, so all air is vented from passenger side in and sucked out on the driver side.
