SOLD Mopar Ron Francis Dodge, Plymouth & Chrysler EXPRESS Wiring System Kit - XP-68
RoadRunner1970
1:56 PM
USA
Feedback: 7 / 1 / 0
Complete Mopar Wiring Kit for sale, Ron Francis still new in the box. Paid almost $500 for the kit will sell for $300 plus shipping.....Didn't need it.....Thanks Brian
Wiring for one-wire alternator (external alternator users add VR-99). This kit will wire points, aftermarket and electronic (factory or dealer supplied) distributors. It also allows for connecting the Chrysler starter relay for use of the factory transmission-mounted neutral safety switch. Our printed and color-coded HIGH TEMPERATURE fire-resistant wiring is supplied for all circuits, including for the lighting needed for most safety inspections: Hi & Low beams, indicator lights, brake, turn signal, parking and third brake light. The EXPRESS has been improved over previous models to simplify and speed up installation, facilitated by our famous COLOR CODED INSTRUCTIONS. The kit includes a headlight switch, isolated cooling fran relay and a unique serial number that allows us to give technical support to you and any subsequent owner.
Features Include:
*Clear Coated, Polished Stainless Steel Finish
*18 Circuits on 16 Fuses
*4 Select-A-Circuits
*Faster Installation with New Style Terminal Block
*Cooling Fan Relay Included
*Only the Best Quality Wire and Terminals
*Proper Size Heavy Wire for Each Circuit
*Handles 100 Amp - or higher - Alternators
*Serial Number
*Includes the Proper Connectors & Terminals
*Clear, Simple, Color Coded Instructions
The Express is a direct replacement for all previous Ron Francis Wiring kits. It has a very similar bag structure to the past models. All variations of alternator, distributor and steering column are available. Along with the cooling fan wiring and the Multi-Connection Battery Juntion Block, it has 16 fuses, 4 of them select-a-circuit, and 18 Circuits for complete flexibility in building it your way.
16 Fuse = 18-20 Circuits
Our newest custom wiring system is built specifically for your Mopar Powered vehicle with all the connectors and wiring necessary to drive it, pass inspection, and be able to add accessories as you see fit, now and in the future. We have included the cooling fan relay due to the fact that more and more customers are using electric fans. Now you can have everything centrally located for a cleaner installation! We've also added a Multi-Connection Battery Junction Block to reduce the number of wires going to the starter for all those add-ons in your custom Mopar powered application.
Panel measures:
4-3/4" W x 7-1/2" L x 3-3/8" H
