belvedere 67
I recently bought a painless wiring harness for my 67 belvedere. This is my first major project and have a few basic question. I turn the key nothing happens. When I check the starter solenoid I have power. When I check the ignition switch I have power at 1 terminal. When I turn the key I have power at three of the terminals coming out of the ignition switch. I have power at the battery lead at the alternator. So here's my questions. With the battery hooked up should I have power at the coil , voltage regulator , ballast ? Right now I don't have any of these. Or does the key need to be on to get power there. The motor turns over when I jump the starter solenoid with a screwdriver. I know these are basic questions but any help is greatly appreciated. thanks.
