Brandy
Jack Stand Racer #6..and proud of it!
- 12:21 PM
- Oct 16, 2014
- Salisbury, Vermont
I have their pushrods in my 440.
Thanks! Good to hear yours worked well for you. I was a little hesitant because it was out of a motorhome, but it is only supposed to have just over 10k miles on it.I have the same casting number 4006630 except mine is 440-1, same pad stamp of 8T 440 E. Mine came out of a motorhome as well. Will be a nice addition to your Belvedere.
The whiplash cam is tricky to tune since the idle is pretty rough.Hughes sells a whiplash cam for the RV engines that’s supposed to help. The Summit K6401 is a cheaper choice though and a decent cam.
You are correct, mine liked 15deg initial timing with the vacum adv unplugged.The whiplash cam is tricky to tune since the idle is pretty rough.
The Summit cam has a smooth idle but makes good power around 2,500 rpm and has great low end torque.
My RV 440 was a 75 block had 452 heads with a cast crank and LY rods. Not all RV engines had steel cranks. Pictures below show the extra coolant ports.Biggest differences that are found on motorhome 440 engines are a steel crank and six pack rods being used. Heads can also be different with more water passages. There is even a 452 head for RV's that have the small peanut type plug.
The engines built with the raised water pump are 361/413 engines and are very different up top above the short block.
These are what most refer to as "industrial" engines, and even they came with 3 different packages depending on the applicaton.
Doesn't touch on what subject?The 440 source article has good info on casting and webs etc but unfortunately doesn't touch on this subject whatsoever
The guy ended up having a non industrial motor, hopefully it's useful.Doesn't touch on what subject?
Some " Industrial/cold weather-truck" blocks 440-426-413 look like this..
Wow, that is quite abit of extra cooling ports! Your engine looks great. I am on the fence about painting it blue or orange.My RV 440 was a 75 block had 452 heads with a cast crank and LY rods. Not all RV engines had steel cranks. Pictures below show the extra coolant ports.
I used a 76 RV 440 in my coronet. 38k on it.The guy I got mine from had a video of it cranking over building 40+ psi of oil pressure. My intention is to change the pan, pull the valve covers, change the intake and carb. add headers, clean and paint it, and see if it will run ok for now.
