soundhd
In the process of replacing the Federal PS pump that came on the 70 RR I bought with a Saginaw type pump (the correct one). Had to buy everything new, pump, brackets, hoses and bolt kit.....anyway question is which bolts are used to do what (photo of bolt kit is below).
Kit came with 2 studs..looks like one is needed for one of the mounting bolt locations for the rear mounting bracket (hole is in a recessed spot)..do not have any idea what the other stud is for (used the other one for the other rear mounting hole...seemed to work ok) .....used two of the short bolts/washers for the front bracket, long bolt is for the upper mount hole on the motor and the large nut is for the pulley.
Any advice or photo of rear bracket mounted on pump would be appreciated....service manual does not show anything..
thanks
thanks
