MSD Pic
Bigal75
2:09 PM
Ottawa Ontario Canada
I need ideas on where to mount my MSD box - doesn't seem to fit in the engine compartment and I have my radio in my glove box.
Where did you mount your MSD box and could you post pics?
Not a good picture but this is where I have mine
Mine is in the same position as bobtile.
MSD recommended not in the glovebox. I know many have it there without problems.
I put mine where it is due to the wiring ran right by it so it made sense to me.
Good luck
I think I'll mount it inside where the floor/firewall join on the passenger side. It's out of the way and easily accessible.
If you're racing it that's fine. If you have passengers, you don't want them kicking it.
Mounted mine like Bobtile only vertical (6AL2) Blaster on fender wall next to. Out of way and cooled by elect fan.
i mounted mine on the radiator support panel just behind headlight, sorry no good pic
Mounted mine on the heater box
Don't use 3M. When it gets hot outside it will not hold. I put mine on that side also but used the mounts provided. I mounted it to the fire wall on the inside the car.
