68sportsatelliteragtop
You can't just post cool stuff like that without explaining how it works. Is there a splitter that runs the tach and RPM limiter?
The cable drive limiter grounds out the ignition at the pre-determined RPM setting. As you can see, there is no marking for specific RPM so it is adjusted with the use of a tach. How another cable drive tach is used along with the limiter I don't know, maybe there is a dual drive or splitter available.
I never could get used to the vertigate I had in a different car than the Charger above. I have been thinking about trying it again but hate to hack up the floor. How much has to be trimmed to fit that setup?[/QUOTE]
The Vert-i-Gate requires a BIG hole cut into the floor pan, but also had a Big boot to cover the hole......
