- 11:15 PM
- Dec 21, 2017
- taxifornia,soon 2b Arizona.
I can maybe take a pic of a 4.625 billet alcohol crank, if that will help, LOL.
Probably not, with eight flywheel bolts.Could be an old chevy six cylinder with that gear on the front. How many rod journals?
(Must be a small camera)
Well there's nothing better than playing charades with auto partsProbably not, with eight flywheel bolts.
So it was a trick question! Like a 354 hemi , maybe a waterpump hemi.. def not a 2.6 hemiIt is a hemi.at the beginning of the discussion are the pics of the back of the shaft. The area in question
It appears to be a crank for the 413 1960-1961 .In that application the studs are in the converter hub and the holes in the end of the crank are offset so the balance is correct. On the early set up even the 331-354-392 all had converters that bolted to the crank and the cast iron torquelfite was held in by 4 large bolts and there is a torque sleeve that indexes to the front pump of the trans and then into the converter as you slide the trans back in. If you measure the length of the crank it will be longer than a 383-413-440 late model- because the flange is closer to the converter. If you give me the casting number I can tell you the year and engine.This crank was in the boxes of parts I acquired. All I know is the hemi has 8 bolts at the flywheel. Rods and mains are std hemi. What set up is this on the back of the crank? No ridge for flywheel or flex plate.
Is there a application for this set up?
Thanks
You mean the forging number??If you give me the casting number I can tell you the year and engine.
How do I give a thanks and an agree?Industrial 413 crankshaft.
It has a flywheel with a recessed register machined into back.
It uses the outside diameter as the centering device not the usual one.
It also has a reverse direction camshaft that has a huge gearwheel on the camshaft.
How do I know lol?
Building one into my 413 D200 dodge truck with a NP 5 speed gearbox.
It should be obvious that the cam would be reverse rotation with a direct gear drive where as a chain drive makes it turn the same as the crank rotation. How were marine engines set up?? I know if a boat had dual inboards one has to (or should) turn opposite the sister engine unless there's a gearbox in the mix.....Industrial 413 crankshaft.
How do I know lol?
Thank you. We've had several threads about non passenger RBs, and this puts fact before fiction about the different cranks. Ie motor home motors etc. Some industrial cranks are usable, some aren't. (In a muscle car)Industrial 413 crankshaft.
How do I know lol?
Yes marine motors have a reverse engine. But some of the passenger 6 cyls had gear drive.It should be obvious that the cam would be reverse rotation with a direct gear drive where as a chain drive makes it turn the same as the crank rotation. How were marine engines set up?? I know if a boat had dual inboards one has to (or should) turn opposite the sister engine unless there's a gearbox in the mix.....
Marine engine builders had two options, early days they used an opposite rotation engine in many single, as well as the port (left for you land lubbers) engine in duals, as stated they used a gear drive and different cam. Now the drives are able to change prop rotation so no need for a goofy f-ing engine. The gear doesn't necessarily mean it's opposite rot. if there's also an idler gear...right?It should be obvious that the cam would be reverse rotation with a direct gear drive where as a chain drive makes it turn the same as the crank rotation. How were marine engines set up?? I know if a boat had dual inboards one has to (or should) turn opposite the sister engine unless there's a gearbox in the mix.....
This dist and the piece next to it came from a 413 marine. The piece on leftIt should be obvious that the cam would be reverse rotation with a direct gear drive where as a chain drive makes it turn the same as the crank rotation. How were marine engines set up?? I know if a boat had dual inboards one has to (or should) turn opposite the sister engine unless there's a gearbox in the mix.....
