Need help decodeing fender tag
Moparman383
10:19 PM
Mt.airy
69 roadrunner lynch rd. I think. top to bottom
926 593 093
7w
B5 b5 h2w w1
Rm21 e63 d32 a28
thanks for any help.this is my first roadrunner.
926 593 093
7w
B5 b5 h2w w1
Rm21 e63 d32 a28
RM21 = Road Runner - Post car meaning center post between front and rear windows.
E63 = 383 HP 335HP stock motor
D32= Heavy duty transmission Automatic
A28 = Calif. noise reduc. pkg. - More sound insulation added
B5 = EXTERIOR COLOR BLUE
b5 = Door jambs etc. color Blue
W1 = Hubcaps
Not sure what h2w or 7w is could have something to do with the heater. you sure you wrote it down correctly?
Can you post a pic of the tag?
Still working on the rest, helps if you have the vin
E63 = 383 HP 335HP stock motor E63 only tells you 383-4bbl. It does not tell you which version or HP rating of the car. You need other info to determine that.
A28 = Calif. noise reduc. pkg. - More sound insulation added Scheduled production date of October 28, 1968
B5 = EXTERIOR COLOR BLUE Bottom part of car painted blue
b5 = Door jambs etc. color Blue top painted blue
H2W interior trim code. high trim level, vinyl bench seat; white
W1 = Hubcaps Inner upper door frames painted white to match interior
(V)7W White accent stripe
926 = engine assembly code = B body 383-4bbl, 335 horse, orange
593 = rear axle assembly code = B body 8.75 with 3.23 gears, open rear end, 11" drum brakes
093 = transmission part number = 2892093 = HD automatic behind 383/440s
