THX264 degrees duration, .450" lift, 108 degrees lobe centres (separation), 222 degrees duration at .050" lift. Pretty tame RV. camshaft. Pretty close to factory camshaft used in 383 4 Barrel engines (non-RoadRunner).
Is there any way to find out if I have a NEW/never used cam shaft ????
What would you estimate the value $$ of this camshaft ????264 degrees duration, .450" lift, 108 degrees lobe centres (separation), 222 degrees duration at .050" lift. Pretty tame RV. camshaft. Pretty close to factory camshaft used in 383 4 Barrel engines (non-RoadRunner).
Is there a wear pattern on the lobes?Is there any way to find out if I have a NEW/never used cam shaft ????
It looks fine.....I got it straight from Gary PavlovichIs there a wear pattern on the lobes?
The box looked pretty good.
The box looked pretty good.![]()
Why not ask him?It looks fine.....I got it straight from Gary Pavlovich
Thanks for the help (it does have the coating on the lobes)A new cam will likely have a black/dark gray anti wear coating on the cam lobes. That coating wears off after a few miles.
I would say the cam is a good street grind. I have used a cam grind similar to that lift and duration in dirt track street stock engines that require a .450 max lift. Both in à 318 and small block Oldsmobile.
The 108 lobe center is what will limit that cam on the street as a wider LC like a 112 will spread out the power band. It's usable for sure but is more for performance.
Let the beatings begin.
Solid LiftersIs it a hydraulic, or solid lifter cam?
If it’s not a solid, those numbers suggest that maybe the advertised numbers were measured at 0.008” lobe lift.
