1969 beep beep
I tried running 5 quarts and took it out for a test drive. I still found oil in the distributor, but not as much. I am going to try a leak down and see what happens.
We have a member here who made the most torque and HP in a dyno contest with 56% leakdown on one cylinder and at least 10% on all the rest. It was over 700 HP. I'm not an advocate of leakdown.....just stating for the record.
All that said, I think until you get 2500-3000 miles on it, you're over reacting. Drive it some. Clean it up when it gets dirty and go from there.
Rings should be seated by now. It only take a couple hours to do... I hardly see the harm in it.
It depends. If the block was honed with a torque plate, I tend to agree. If not, then it's anybody's guess.
Thanks everyone for all the feedback. Here are my leak down results with engine warm:Cylinder # 1-9%, 3-8%, 5-8%, 7-8%, 2-10%, 4-8%, 6-8%, 8-12% Yes the engine was honed with a torque plate.
Thanks 70rr-brian. I am going to look for a used distributor which I can try. What about a deeper oil pan or different windage tray. There could be a lot of splash causing oil to pool beside the distributor. I can't see how it could be going threw the distributor with .001 th spacing on either side of the distributor shaft. Does anyone know what the shaft spacing is on a new msd or new mopar performance distributor?
From wikipedia:"Leakage is given in wholly arbitrary percentages but these “percentages” do not relate to any actual quantity or real dimension. The meaning of the readings is only relative to other tests done with the same design of tester. Leak-down readings of up to 20% are usually acceptable while greater than that requires a repair. Racing engines would be in the 1-10% range for top performance."
Dryheat, I am running the Mopar Performance 3690431 View attachment 87706
I tested the car again today, after adding another shim and completely blocking the oil port holes at the base of the distributor. Well I set the end play to .010th and sure enough after beating on it again, oil is still coming out of this distributor. I think I need to remove the distributor, and drive the oil pump with a drill so I can see what is happening inside the distributor hole.
