Oddity today. Car always turned around ver and started with no effort. Today, it seems that I am not getting power to the coil. Now it spins and no fire.
Thoughts?
Thoughts?
I looked and the back is sealed(or at least a closed panelOpen up the box. You'll probably find the power wire melted off inside. .
I've repaired more than one. The box comes apart.I looked and the back is sealed(or at least a closed panel
There should be a small red LED on the box, if it is flashing while cranking your distributor is sending a signal to the box. You can also take a jumper wire and make the box fire as well to check it. Troubleshooting TechniquesOddity today. Car always turned around ver and started with no effort. Today, it seems that I am not getting power to the coil. Now it spins and no fire.
Thoughts?View attachment 1516983View attachment 1516985
