Need help with MSD ignition
Justasgood
4:56 PM
Covington, La
Oddity today. Car always turned around ver and started with no effort. Today, it seems that I am not getting power to the coil. Now it spins and no fire.
Thoughts?
MSD 6A/6AL DIGITAL CHECKING FOR SPARK
If triggering the ignition with the White wire:
1. Make sure the ignition switch is in the “Off” position.
2. Remove the coil wire from the distributor cap and set the terminal approximately 1/2" from ground.
3. Disconnect the MSD White trigger wire from the distributor.
4. Turn the ignition to the On position. Do not crank the engine.
5. Tap the White wire to ground several times. Each time you pull the wire from ground, a spark should
jump from the coil wire to ground. If spark is present, the ignition is working properly. If there is no spark skip to step 6.
If triggering with the Magnetic Pickup:
2. Remove the coil wire from the distributor cap and set the terminal approximately 1/2" from ground. 3. Disconnect the MSD magnetic pickup wires from the distributor.
5. With a small jumper wire, short the MSD’s Green and Violet magnetic pickup wires together several
times. Each time you break this short, a spark should jump from the coil wire to ground. If spark
6. If there is no spark:
A. Inspect all of the wiring.
B. Substitute another coil and repeat the test. If there is now spark, the coil is at fault.
C. If there is still no spark, check to make sure there are 12 volts on the small Red wire from the
MSD when the key is in the On position. If 12 volts are not present, find another switched 12
volt source and repeat the test.
D. If, after following the test procedures and inspecting all of the wiring, there is still no spark, the
MSD Ignition is in need of repair. See the Warranty and Service section for information.
That's MSD for you!!!
Just fired up a 440 last week using the MSD version of the GM 4 pin HEI module. Got about 1.5 hrs run time out of it....& then no spark.
