Whiplash72
I’m rebuilding the 360 that was in my 72 charger. I shooting for a mild performance build that brings the life out of the engine without completely killing my wallet. I need help with cam and carb selection. This is my first engine build/rebuild.
I’m looking to use the comp cams 20-214-4 camshaft and a Holley 4150 650cfm double pumper. Are these wise choices?
The specs I’m working with are as follows:
Block:
-casting number 4179930
-block has a deck clearance of 0.005”
Crank:
-looks to be factory cast crank
-casting number 402716(9)
Heads:
-casting number 3418915B
-2.02” intake
-1.60” exhaust
-max valve lift looks to be around 0.472”
-head volume of 69cc
-stock stamped rockers
Intake:
-Edelbrock performer rpm dual plane
Pistons & Rods:
-Speed pro hypereutectic H116CP
-Rods have casting number 3418645
From some calculations, it appears I’m making roughly a 9.7:1 compression ratio, which is where I’d like to be.
I appreciate everyone’s wisdom, as my engine experience comes from Google and the gas pedal.
Block:
Crank:
Heads:
-2.02” intake
-1.60” exhaust
Intake:
Pistons & Rods:
