PRHeads
- 5:43 PM
- Aug 31, 2018
- So. Burlington Vt
Also on the dyno they usually are getting nice cool air, that may also be part of the problem.
This is a very real thing.
Most guys aren’t running the motor on the dyno at 190* water temp...... or with the air inlet temps that can easily be over 100* in the vehicle.
Which can have a very real impact on what the “real world” octane requirements will be.
The other thing no one has touched on in this thread is....... the dynamic efficiency on the motor at WOT, in the rpm range where the pinging is occurring.
For example, it you removed the 4bbl carb and installed a tiny 2bbl, at WOT the VE would drop way down, and so would the cylinder pressure....... and the octane requirement.
Along the same lines would be heads that didn’t flow as good, or a more restrictive intake manifold.
Some of the things that make more power, do so by improving cylinder filling...... which increases cylinder pressure...... which can push up the octane requirement.
In other words, “by the math”, you could have two motors with the same CR, and calculated dynamic CR, with the same quench, cam profile, etc....... and have one run on lower octane fuel, if the induction is restricted, and the running dynamic efficiency is lower.
Of course........ it would also make less power as a result.
Assuming the info on the build sheet is correct, and adjusting a few specifics to end up at just under 10:1CR....... the dynamic CR ends up at just barely under 8:1....... which is the theoretical tipping point for premium pump gas.
So....... maybe it would be fine in a place that 93 was still available, and the 91 just doesn’t get it done.
I don’t know if E10 93 is available where the OP is, and that the 91 is the non-ethanol stuff.
We have both of those here, and I have a late model muscle car........ and it seems a little sharper on the 93 E10.
Keep in mind that new cars are constantly monitoring for ping, and adjusting the timing for peak performance.
So, I just assume the 93 runs a little better because it allows the computer to get more aggressive with the tune.
