Wietse
Hey all,
Got a bit of an issue here with my new fuel pump (Carter M6903) for my '69 440 Coronet R/T.
There is plenty fuel coming from the supply line, once i release the suction hose it is pouring out.
Using a vacuum pump and pull the fuel through the pump and filter also shows plenty fuel coming through.
When cranking the engine with the pump discharge hose disconnected and put in a bucket there is no fuel coming at all.
Checked the push rod in the engine which slides nice and easy and made sure the pump lever sits in front of it. (guess that if that is not the case it will not go in anyway)
The pump lever has a small stroke of "easy" movement which is against the spring that can be seen, after it gets very hard but returns to it's original position. (Compared with my old pump it feels the same)
What could be the issue here?
Being able to suck fuel through shows there is no blockages, has to be the pump imo.
Just to confirm, there should be nothing in between the pump push rod and the operating lever right?
Nothing that could fall out and end up in the sump?
