Dibbons
- 12:00 AM
- Nov 29, 2014
- La Paz, B.C.S., Mexico
The 340 is using the Petronix distributor previously installed in the former 318 which never had a problem. This new rebuild will not stay running for more than a couple of seconds. I am turning the key on and then using a remote starter switch which I believe would indicate it is not the ballast resistor (which I believe is normally bypassed when using the ignition key to crank the motor). I will probably remove the intake manifold today and see if the new camshaft and lifters are still OK after so much cranking. Very nerve-wracking when this happens (does not run long enough for me to get a read on the ignition timing either). Thank you.
