68coronet
I added a small 125 shot of nitrous. Question on numbers I'm getting. Car is a 68 coronet .030 over 440 ported and polished eddy heads roller valve train, flat top Pistons, 4 sp with 3.91 gear ratio making 425hp and 481 lb ft at the wheels. Added nitrous and getting 465 hp and 599 lb ft at the wheels. I am running atomic efi set up to control timing, separate pump running 6 psi for nitrous. Retarding timing 4 degrees when nos is activated, afr drops to 10.2-1 then comes back to 11.5-1 which is where I read it should be with the nitrous. I am not complaining about the torque numbers just wondering on the hp numbers of I'm missing something? This is my first round with nitrous.
