Heimedw
Hello I'm new to the form and have a electrical question. I have a 1964 dodge polara . The question I have is, everything works in the cluster but the back lighting. I check for power at the inst fuse. I have no power on either side of the fuse. Does the power come from the cluster to the fuse or from the headlight switch to the fuse? I know that the headlight switch has to be out one or two clicks for the backlighting to come on but I don't know is if the back light have power at all times and the headlight switch completes the circuit or if the headlight switch supplies the power when on? I pulled the headlight switch connector and checked the tan wire for power with the ign turned on. No power found so I'm at a loss.
any help would be great
