no dash lights on 73 challenger
steve maluk
12:35 AM
johnson city tn
I am having trouble with my dash lights not functioning / dimmer bench tested good / light bar has good ground no power to light bar/ light bar connects to the orange power source under dash with the console shifter light neither are working so according to the factory wiring diagram the power to the orange plug comes from the radio connector?????? any suggestions thanks all
The orange molded lamp connector is fed by a 5amp fuse directly below the horn relay on the fuse block. Check that.
when i check the 5 amp fuse with meter it shows good how do i know if there is any power going through the fuse i am not very savy with a meter but just basics thanks
Remove the fuse, set the meter to ohms, put the leads on each side and the meter will zero out if the fuse is good. Now do the same from the fuse block connector to the orange molded connector, it should zero as well. The outside fuse connector is the feed to the molded connector.
You can also check for 12v on both sides of the fuse then again at the molded connector.
