No power on brown wire from the ignitionswitch to the coil.
__Larsson____
9:33 PM
JONKOPING
So first off the wiringharness isnt an OE spec harness, it's from a guy who made harnesses here in sweden but no longer active.
I am trying to figure out if i have done something wrong in the process.
I do not get power in the brown wire (that i guess i should?) thats coming from the ignitionswitch when i turn the key.
(NO amp gauge)
So from my harness i have 6 wires
(Big Red that says to connect to BAT which i think is the Big Red from the switch).
(White connect to Ign1 / coil which is the Brown wire)
(I have i black wire that connects to the Blue which give power to the to the headlight doors and such)
(Yellow connects to a Purple to the starte relay)
(And 2 small red/black wires that connects to the Big Black wire from the switch)
So basically i only get power through 4 out of 8 wires.
I can crank the engine and all lights work.
I did a test and connected a new ignitionswitch with no difference.
I hope i explained in a good enough way.
’70 ignition switch lead coding?
Yellow- Start-crank, starter relay, 12 volts in crank only.
Black- accessory, 12 volts in run and accessory positions.
Blue- Ignition 1, 12 volts in run position only.
Brown- Ignition 2, ballast resistor bypass, 12 volts in crank position only.
Red- Battery feed in, 12 volts.
18ga orange, if present, column auto gear select light.
Two small red wires, key-in switch leads.
Oh, so brown only have 12v at crank, then i need another 12v at run position for my EFI
Then you'll have to push your car around with open headlights? I guess
Connect the blue (ignition 1) and brown (Ignition 2) wires together for 12 volts in both crank and run. There are a couple of other threads going on here on that subject presently.
so they work together? I just have to figure out how to do it in a good lookin way the =S
