PurpleBeeper
Another option - I've run into something similar. Is the intake "anything special"? If not, you may be able to mill the intake manifold to match up to the engine/heads as is.
I've not done this myself, but I read about this somewhere and bought some PRECISION machined washers and some plastiguage I think (?) to figure this out. Basically, you set the intake up on top of the precision washers and squeeze plastiguage top/bottom at all corner ports. The plastiguage has to be thicker than the precision washers. Subtract the thickness of the washers and you know the gap (top & bottom of the ports) at each corner. That should be enough for a good machinist to mill the intake BUT, I would suggest you find a good machinist and explain the situation. He might want something different to help him mill your intake correctly.
