OEM talight gasket
tomlin
1:50 AM
Cantrall,Ill
Does anyone know what Dodge used for a tailight gasket on the 66 Charger? I am talking about the once piece gasket that went between the light assembly and the body. The one I had on it was white foam. It didn't look correct and appeared to have leaked or been leaking. Looks like a piece of crap to be honest.
Yes, I believe it was white foam. Only reason for it was to stop squeaks and movement noise.
If it is leaking, it is probably the lens gasket.
Thanks for the info. I noticed some corrosion behind the foam when I originally took it apart. That's kind of why I figured it may have leaked at some point. Honestly though, come to think about it there was not a lot of paint in the area from the factory. She is painted now and I doubt it will ever corrode there again. I will either purchase the correct foam or make one out of adhesive weatherstrip. Thanks again!
the one I took out was white foam I thought it may have been replaced but maybe not .still working there but I was thinking weather stripping sticky one side you can buy many thicknesses
