Encswsm
My 66 Charger came with a 360 with a 1973 date code. I have no idea what has been done to this engine prior to my ownership. I upgraded the front end to Disk brakes and a Borgeson power steering unit. While bolting my new Power Steering pump in the bolts that bolt into the water jacket pulled out because the holes were rusted. This required the removal of the timing cover to access and repair the bolt holes. now I cant get the Dang cover back on due to the thick rubber oil seal at the top edge of the oil pan. I did a little research and figured if I lowered the oil pan I could bolt the cover on. Now here's the problem I have removed all the bolts from the oil pan and it seems like the PO used like about 53.6 gallons of RTV and the pan is essentially gluing it in place. anyone have any ideas on how to lower the pan short of yanking the whole engine?
