skrcsmith4
Whats a healthy (idle) oil preasure reading on a 383.
would you mind elaborating a little more on that last statement!a stock 383 will have had a red 45lb pressure relief spring. pressure may vary a little depending on oil viscosity. street hemi's had a black 65lb relief spring. the aftermarket high volume pumps will have 75lb+ springs. half groove stock main bearings will maintain a higher average pressure thru the rpm band but won't exceed the relief rating. basically if your engine is stock it should run 45-50lbs running pressure; idle may dip to 25-30lbs, depending on oil viscosity. too much pressure isn't good. it's hard on parts and for the most part unnecessary.
One problem with oil pressure being too high is that it can blow out the seal on the oil filter. And depending on the design, the oil filter base could be distorted. Some 90's B250 Dodge vans had problems with oil filter casing distortion when the psi went over 80 due to a faulty pump.
eats up the intermediate shaft and shaft bushing. also loads the rotors wearing the pump cover. pressure is resistance to flow. doesn't mean you have more flow.would you mind elaborating a little more on that last statement!
That is why volume should always be increased before increase pressure.eats up the intermediate shaft and shaft bushing. also loads the rotors wearing the pump cover. pressure is resistance to flow. doesn't mean you have more flow.
i agree with that. i think the #1 priority should be to feed the pump.That is why volume should always be increased before increase pressure.
valve covers shouldn't anything to do with it. probably have a high volume/high pressure pump with heavy oil. change the spring in the pump and reduce the oil viscosity.what could be the cause of high oil pressure reading. It use to read around 50 until I changed valve covers. (mopar performance). Also changed oil cap and pcv value.
i've noticed that a lot of the pump castings don't match the feed hole in the block. this needs to addressed. going to a larger pick-up helps feed the pump. try to radius the right angle turn in the pump feed passage in the block. an extra quart or two sure won't hurt nothing.And how do you do that? Bigger oil pan? Is their a calculation for higher pressure vs oil pan sizing?
