firiepete
After my 440 rebuild I had the same oil pressures. I changed the pressure relief spring in the oil pump to a Hemi 426. Oil pressure @ idle approx 15-20. Pressure when cruising approx 50-60psi.I have a 66 Belvedere with non original modified 440. Oil pressure is between 70 and 80Psi when first started, After warm up it drops to 18 or 19PSI @ idle. Should I be concerned?
Thanks, Ken
