- 4:30 PM
- Jan 16, 2011
- NorCal Sierras
All My N/A race engines used
Torco TR-1R 20-50 {hot} or 10/40 {cold} $9.95 a qt.,
I never skimp on oil, especially in a race engine, it's the life's blood of you engine,
it works for me, I stick with what I know works...
disclaimer;
Please don't take what I say as an insult, not my intention
1 oil & viscosity doesn't fit all, it never has never will...
I rarely do what someone on the Internet recommends,
I do what the engine builder {reputable} & my experience tells me,
I know what works for me & I stick with it !!
Unless something proves me wrong or "the experts"
tells/proves to me otherwise...
Both my Daily Driver 99 Dakota SLT 4x4
Stock OE 5 qt. pan
Harlen Sharp 1.7:1 rollers, AEM air box & TB spacer,
Edelbrock headers, Hypoertech tuner, 3" cat back Flowmasters etc.
a bunch of Bolt-on performance stuff
& my street/strip car 479ci/6bbl full roller has
all gridded up all flash/excess, not too extravagant
& especially all returns/drains inside the block,
I have screen epoxied to the area over the camshaft,
redirect the oil away from dripping down on the crankshaft,
thru the camshaft holes, hammering the crank @ rpm, killing HP
{40 year ol' engine builders tip, hasn't failed me yet}
the car has a 7qt Milodon low profile pan & pick up, with windage tray
& baffles in the bottom of the pan both for deceleration & hard cornering
Royal Purple 10-40/20-50 respectively
Synthetic, both are full hydr. rollers...
great bang for the buck, for an off the shelf reasonably priced
mass produced synthetic...
I'm in an area that doesn't get overly cold
or I don't drive "my car" when it's too cold, I drive my truck}
& is hot 100*+ sometimes in the summertime
BUT;
I'll probably go back to Torco in my RR,
when I drive it more regularly...
Old habits die hard,
I am a brand loyal ol' cuss, when it works...
so far so good
I use to use Redline for years, ol' sponsorship,
but started using Torco, because of problems,
latter they {Torco} gave me oil
{Vic Hubbards sponsor, oil, fuel, plugs, filters}
it's not cheap, but never had any oil related failures "ever"...
Stick with what works, in extreme heat maybe a thicker oil
extreme cold maybe a thinner oil, multi blends
have kind of the best of both worlds...
There are far many more factors to weigh,
when it comes to oil viscosity & what additives it has even...
Do some research/due diligence...
IMO don't just go by price, brand or what someone else runs,
what they have, may be completely different, require thicker or thinner
or an additive you don't want or need, than what you will actually need...
I also have a buddy that does destructive & engine testing
@ Chevron Research & development, he's tested all my oils,
prior to running & after running it's cycles,
anything from Methanol to Race Gas, pump gas with Ethanol etc.
all looks great or I'd have changed them long time ago...
I trust his expert opinions, far more than, just some dude on the internet...
disclaimer;
Please don't take it the wrong way,
Not that "some here" don't know what they are talking about
or that they're probably 100% correct either,
"for their specific combo" etc.
Now when I ran Methanol especially, Blown &/or Mech. FI
I ran 70 wt Torco racing oil &
changed it every race, sometimes before a race was over if need be,
Methanol has a tendency to get by the rings, no matter what
IF you run enough fuel to make real HP, run enough fuel thru it,
it turns the oil to baby **** yellow, even with zero gap top rings...
IMO there's a lot of misinformation out there,
just do what your combo requires, not what some guy
probably in a totally different state & climate runs & does,
unless your builds are near identical & have alike clearances etc.
or they are an expert...
good luck
disclaimer;
Stock OE 5 qt. pan
BUT;
so far so good
disclaimer;
good luck
