cr8crshr
- 12:04 AM
- Feb 13, 2009
- Northwest Nevada
For those that have been following my trials and set backs with this project, here is where I am at...
I just got my new Rocker Arm hold downs, shims and spacers to swap out and see if I can get the Valve Train on my 383 to quiet down. I also have a push rod measure to see if my push rods are correct too. I will be most likely be working on it over the weekend if my Bowels :bootyshake: hold up for me as I have the dreaded re-exam for my Colon. Any way, I will give this a try and if all things work out now then I will get the car to the tranny shop to get that issue looked at. If this fix fails then most likely I will just get a replacement engine block...either a 400 or another 383... and purchase a stroker kit, Swap out parts on the present 383...heads, lifters, cam, pumps, etc. and give a try at something different. This time I won't be farming out the build but instead I will build it myself. That way I know it will be done right and if not then it is on me and not someone else. At least I am attempting to make progress but moving forward is at a snails pace. Hope this will do it and I will keep the updates coming as I know more....cr8crshr/Tuck
