oldbee
"Way past my pay grade"(!) but a very interesting thread. I've done seemingly everything up to 220v and can't quite wrap my head around what it's trying to do. Jeez, now I'm getting mad that I can't figure it out.
Really? Sylvania stopped using that logo in the late 1960s; I guess the manufacturer had lots of what ever that thing is on the shelf.FYI, the charger is from the early 1980's. Thanks for your continued help and advice!
I do not see any large 'filter' capacitors in your pictures. If this is a half wave rectifier, then the AC you are measuring might be okay. The battery connected becomes the 'filter'. I do agree it is strange that the off position has any voltage present.Why didn't I do this before??? I just tested the power output at the battery cable end. It was not registering on the D.C. scale so I switched it over to AC. When set to 12V, it read 26.8 volts. It didn't change no mater what switches or dials were changed except for the switch to output 6V, and then the voltage dropped to 13.6 volts.
Even when the switches were set to OFF, it still output the voltage shown above.
This has got to be a pretty simple problem to fix unless I am way wrong.
The contacts inside the timer switch (the only one I opened so far) looked pristine. I don't have any Deoxit, but I will get some.I do not see any large 'filter' capacitors in your pictures. If this is a half wave rectifier, then the AC you are measuring might be okay. The battery connected becomes the 'filter'. I do agree it is strange that the off position has any voltage present.
Have you spray soaked all contacts with DeOxIt? It is just a simple thing to do just to add some confidence the switches are doing what the design intended.
Infinity one way, but 88.6 ohms the other way. Shouldn't it be 0 ohms?Me thinks you already did-infinity one direction, 0ohms the other.
