Montclaire
Hello, I’ll be building a 440 in the near future. This will be an “old school” build - no stroker kit or turbos, just a 440.
I’m starting with a seasoned 73 block, supposedly with 50k original miles on it. I’m fully expecting to find a cast crank inside which will be fine for what I need.
I have a vintage MP 509 cam kit and a pair of worked 915s that I got second hand. The heads are cut for bigger valves (can’t remember the sizes offhand) and I added a set of springs good for 510 lift from a set of 440 Source heads with comp cams hardware.
Intake is an A&A cross ram with 440 ports and I believe twin 500cfm carbs. Rear has 3.91s and I’m using a beefed push button 727. Converter is a 70s 360 piece that should stall around 2400-2600.
What I am wondering is this; this motor is rated stock with a 8.2 CR. The 915s should be good for a full compression point over the 452s. Should I just stop there and call it a day?
Most threads that I read these days recommend around 9.5 CR, and I’ll be dang close to that as-is. I used to be able to find 94 octane locally but I think 93 is the best they can do in 2020.
This is not a race car, it will be street driven occasionally to work on nice days and for an ice cream a couple times in the summer. I want a mean sounding big block that I can romp on from time to time and chirp the tires but won’t grenade itself or cost 10k to build.
Thoughts? You won’t talk me out of the cam so just accept it and move on. Thanks
