- 3:42 PM
- Jan 23, 2009
- New Jersey The State of Tax Theives
The vacuum at idle is 5 Inches? Did you check your intake manifold gasket? I do not mean from above with spraying using a rattle can. Did the intake manifold gasket get replaced with a good layered gasket? The low rpm vacum is some thing more fundemental> Are you using a hyraulic cam or solid lifter cam. If the lifters are collapsed "hydraulic" then you can have low vac. But first eliminate the easy. Is the intake manifold cast Iron or aluminum? Who torqued the intake manifold? Did you follow a pattern in torqing the intake bolts?? Borrow an infafred temp sensor and check each cylinder at idiot for temp variation. If there is a crack in the intake manifold and it is underneath you will only know by inspecting it. Also you said the motor overheated. Was that before or after the vacuum problem showed its ugly head?? Re the heads the correct heads ? Did some one change the heads at the engine shop? They need to be inspected once you take off the intake.
