I've only used the steel MP style trays but I decided to give Summit's composite piece a try. My question is, are you folks using any sealers with them? I figure a little's needed at the timing cover and rear seal retainer joints, but the rest of it?
I have a Milodon pan by the way, with the typical recessed 'dimples' between the bolt holes. I saw after searching around that some guys filled those with RTV or even JB-weld in some cases? Is that really needed? It does look like the rubber sealing strips on the tray run through the dimples a bit, but is it enough to leak if the recesses aren't filled in?
Thanks!
Thanks!
