Texas charger 73
Awesome. Thanks. Will be hooking all together tomorrow if weather permits,then just put in new sending unit, rubber, vent lines, hang tank and fire up.
That is correct, one of the pictures linked shows the timer/relay and its related harness, including the connector the lamp lead plugs into (noted by "to lamp");
No, not really, nothing to do with a lights on buzzer, big differences between ’69 b-body dash wiring and ’71-74. No key in ignition buzzers until ’70, combined horn relay/key buzzer fuse box mounting started in ’71 for the b-body. The black wire is not a power lead, it is a ground via the key in ign. switch micro switch, via the left door jamb switch.
