I hadn't painted a car since like 2005-ish,
my old silver 68 RR
I did a paint job in my garage in 2017,
another 68 RR in the org. base/clear LL1 Surf Turquoise Metallic
make sure to use a high quality & compatible primers
& a good sealer too
sand & sand some more
the finished product weighs heavily on the prep
I just recently (4+ years ago) did a Base Clear Coat
Acyrilic Laquer LL1 paint style org. paint
I couldn't find much in stock anywhere
I bought all the stuff from
https://www.AutomotiveTouchUp.com
$495 a gal. & $74 a gal. for the clear (really easy to use the product)
about $1,200 total, I got 2 gallons of primer from them too...
with a few cans of aerosol rattle can touch up
like at $20-$28 (?) a 20oz (?) can...
On my 68 RR
They were only people that had it in stock
& at a decent price
at the time &
I didn't want to wait, months on end or pay $2,000-$3,000 ++
for just paint alone for 2 gals & clear
they even made rattle cans for touch up if need be, of both base & clear
it has different black paint & red accents, below the body line & lift-off hood)
it took near 2 gals of base for the roof, trunk, back & (1/2) sides of the car
I was amazed how much paint it took
some guys I know said; 'I needed 7 coats of base'
maybe I should've )
I also didn't do the interior of the trunk or engine bay, it is OK for now, I will
do them when I pull the engine sometime in the future, it's just a driver mostly,
it's a driver quality car & paint now too, I do love the org. color, no fault of the supplies)
I sanded the **** out of it,
primered it several times (3) & sanded/blocked/boarded
the **** out of it
between coats, prior to the layers of primer
It was painted in metallics base/clears,
& really show '
any scratches' & I assume I had paint shrinkage
I put between 4 of base 50% overlay & a 7 total with (3) clear coats
of base/clear coat on the main exterior
I thought I sanded the hell out of it, from 180-220 after the 1st
& 220-320, after the 2nd & 3rd
3 coats, mostly from some minor bodywork, dings & dents nothing major)
& to 600 grit wet-sanded
before the 1 coat of sealer & then paint
I thought I went way up & above what I needed too...
good thing is no dirt in the paint at all no overspray or dull areas
really great coverage for what I did...
At
no Fault of the product at all
this was 1st day out in the sun, no cutt or buff yet
don't pay attention to the date codes either it was Nov 2017
it was still 70*+ outside & 80*+ inside the garage,
when painted
*That was part of my inpatients, I just wanted it done,
be over with it & have color back on the damn car
I didn't want to wait till the following spring...
I wasn't looking for a show car, just a decent/affordable paint job...
It looked great for about a month or so, after it was painted
then slowly I started seeing fine scratches under the paint & clear
a few deeper scratches, I thought would be gone
from prior to all the primer & sealer/sanding again between each coats...
I think I needed better light, that's my story & I'm sticking to it...
I used to paint all my racecars all 26 of them
The single-stage is far easier IMO, goes on much thicker too,
fewer coats needed
I like the product, I did something wrong
I don't know what either, I did all the right steps "I think"
The moral of the story is prep the **** out of it
I thought I did it right...
by the way
77' Corvette has/was a great color of "Bright Yellow" in a single-stage
good luck
