where did yousee that the factory recommended 140?
Hades in July?
It's in the '69 factory service manual Pg. 21-96. Might even be in the owners manual, but I'd have to go check to be sure about that.
4-SPEED TRANSMISSION
Trans. Model ................... A-833 Clutch Housing Face Run-Out . .006” Max.
4 Forward Speeds Clutch Housing Bore Run-out . ,008’’M ax.
Lubricant-Capacity and Type
Valiant, Barracuda U.S. 7 Pts. Imp. 5-3/4 Pts.
Warm Climate-Multi-Purpose Gear Oil S.A.E. 140
Cold Climate-Multi-Purpose Gear Oil S.A.E. 80
or 90 or Auto Trans. Fluid
“AQ-ATF Suffix “A” (Dexron)
Gear Ratio Heavy
Std. Duty
First 2.66 2.65
Second 1.91 1.93
Third 1.39 1.39
Fourth 1.00 1.00
Reverse 2.58 2.58
......................... Satellite ............. 7-1/2 6-1/ 4 ....................... Fury ................. 7-3/4 6112 Warm Climate-Multi-Purpose Gear Oil
Downshift Speed Limits
......................... ........ ............................................. Gear Type ...................... Helical
50 to 25 mph
Tolerances 3rd to 2nd .................... 25 to 15 mph
15 to Zero rnph
