PerTronix Ignitor® Solid-State Ignition Systems anyone using it?
davek
4:37 PM
columbia SC
Want to change from points and a friend suggested Per Tronix. 318, Anyone have some feed back?
I've had one in for years. No issues.
I have converted many cars in the past 15 years. No issues, I suggest that you use their coils.
I suggest you pertronix users keep an extra rotor in the car in case it fails. You cannot go to the parts store and buy one it has the green sensor ring on it to make it function.
Hey Dave, I have Pertronix in my 68 and 70. No problem at all. They work great. Sorry I missed your text earlier.
Man Dave, giving up on the points so soon? Where’s your sense of adventure? :poke:
I put one in a friend's 351 cleveland Mach 1 and it's been going for 8 years. Then helped another friend put one in his inline 6 mustang -- that was four years ago. Both of them drive them weekly.
Using them for over 20 years with no problem.
READ the instructions.Use the proper coil as the Pertronix Kits differ between I II III and the latest offerings.
Some you by pass the ballast. I have always used the Pertronix I kits without fail.
Keep all your points parts in a box in the trunk for insurance and you will never need them.
Mine has a collar that slip on over the rotor. I've been runnin 2 Pertronix II's for over 20 years each with no problems. Good Luck
Pertronix 3 is in the Roadrunner Dave. Only been in a few years but no problems.
Running one of their conversion kits in a boat with a small block Chevy. No problems after 4 years.
Look at the differences in these rotors. White is stock, black is pertronix. How are you going to swap the green ring to a stock rotor? It is too small and too much gap to the pickup. This is what I am looking at when I type my post. And toolman Mike has the same setup.
Now maybe they changed the rotor as the system evolved.
I'm not sure what the issue is. You can pull the hall effect ring from the black rotor and put in on the white rotor. Or use the black rotor/hall effect.
That is standard in the Pertronix 2. If he buys the pertronix 3, there is no collar. Spark is timed off the lobes on the distributor.
I am using the Pertronix 2 in my 62 Belvedere, with solid state ignition box and Flamethrower coil. Retrofit on my points distributor.. Runs perfect. It is about 8 years old.
I also have a pertronix 3 in my GTX. No hall effect, multi spark, rev limiter. Also being used with solid state ignition and Flamethrower coil. Retrofit on my old distributor. Runs perfect.
