Donny
- 9:24 PM
- Aug 28, 2009
- North East San Antonio TX
no prob, everything is relevant! I have a Sullair 50 HP rotary screw compressor, it has no tank. As soon as I turn it on, it's making air, tons of air! In my work, I don't worry about PSI that much; only to move the media through the piping to my blast room. I run nearly 50 psi at my blast pot, which is 85 feet away, so, as the media comes out the blast nozzle it's at about 20-30 psi. The key is cfm; Cubic Feet per Minute. This is where you will spend money on air compressors. But, you can't blast on anything very well if it's under 100 cfm, it will take you forever!
I just completed the 'Cuda convertible and delivered it, I kept accurate blast time records and it took 8.53 hrs to blast the entire car; think about it, that's fast! How long have we all spent on a door or hood or fender with sanding discs? I know I've been there, and done that before; they all have their place and time (grinding down welds, etc) but, as for finding the best way/method, I think I've got it nailed. Too bad you all were not closer, as I'd be able to hook you all up!
