For starters my car runs good. Idles fine and makes great power. Its a 10.0 pump gas 528 hemi on 91 octane. Was dynoed at 642 HP AND 650 TQ. Its a 5 speed manual 3.71 gear rear. Cam is a Comps hydraulic flat tappet 535 Int. and 541 Ex. 112 lobe separation. Indy roller rockers 1.6 Int. and 1.55 Ex. Ready to run distributor not using the vacuum advance. About 11 to 12 inches of vacuum at 1,050 to 1,100 rpms. Timing all in at 35. Pro systems 4150 style 950HP carb. Like I said idles and runs great except at a low speed rpm wise. At light throttle or even de-cel anything lower than 2,000 rpms it has a light surge or ramping condition. I am trying to find a logical way to tune it out. Car has only 250 miles since I put it together. Doing distributor bushings, springs, and timing change the running but not the area I would like it to be. Right now the PV is 6.5. I might be to fussy and have had EFI to long and going to a carbed Hemi is a different rodeo. Thoughts.
